SDS Drill in ceiling voids | on ElectriciansForums
Discuss SDS Drill in ceiling voids in the Electrical Tools and Products area at ElectriciansForums.net
F
Fruits327
Ok people, we all know what it's like like working within a limited suspended ceiling void and trying to angle your drill to where you need to be. I am currently using a Panasonic SDS to do do the job which is quite compact but coming to the end of its life. My major tools are all makita but unfortunately the SDS drills they do are very long bodied and very difficult to manoeuvre within short ceiling voids. I was wondering if anybody could help me with a replacement tool which do the job that I require and save my frustration of drilling at 45 degrees and getting a c##p fixing on everything
Bosch and Hilti make right angle SDS adapters that can be used at reduced efficiency for drilling.
I am not sure if they would fit another make of SDS, presumably they have tried to ensure they do not.
Fairly pricey, to say the least, but if this is something you do all the time I should think it would be worthwhile.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
long? there are two versions a long one and a stumpy version (not as short as the bosch though)
[ElectriciansForums.net] SDS Drill in ceiling voids
if i was going for bosch ii would get the 36v one (batteries are reasonable as well
I am putting some serious consideration into the Milwaukee m12-ch sub compact SDS it looks to be a serious piece of kit and at barebone under ÂŁ150. The only drawback is 13mm max on chuck so it is not viable for bigger jobs. Anybody else looking for a lightweight SDS for drilling 5.5-6mm holes all day long the power and lightweight nature of this drill looks an excellent purchase.
I've got the previous Milwaukee M12 sds (before brushless). It's good for rawl plug holes, but obviously isn't as powerful as the bigger drills on the market.
It's also lightweight which reduces fatigue if you're using it a lot above your head.
Reply to SDS Drill in ceiling voids in the Electrical Tools and Products area at ElectriciansForums.net
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
