Second red 'live' wire in light fitting - what to do? | Page 3 | on ElectriciansForums
Discuss Second red 'live' wire in light fitting - what to do? in the UK Electrical Forum area at ElectriciansForums.net
slquoue
Sheffield
I am connecting a new IKEA pendant light in place of an existing light fitting. I have connected the red wire in the ceiling to the brown 'live' terminal in the IKEA fitting, and the black wire in the ceiling to the blue 'neutral' terminal in the IKEA fitting. However, there is an extra exposed red 'live' wire. Should I connect this to the second available 'live' terminal in the IKEA fitting, or leave it loose as I found it?
[ElectriciansForums.net] Second red 'live' wire in light fitting - what to do?
If the lamp is working (and switching) properly without the mystery red connected, and everything else in the house does as well, then I'd leave it disconnected and insulated, although I'd leave all earths connected together, including the one that is part of this cable, if it's this strange singles + earth stuff.
Connecting the red could be leaving an exposed live cable somewhere.
Very good point.
I've come across sheathed singles in domestic property many times - usually as part of 2w switch wiring, but never with an earth incorporated in it.
All metric T&E was white in colour in my area until recently, which I've heard is another regional thing.
Also 240-0-240 volt split phase electricity supplies, which are common around here, but gets blank looks when I've enquired about motor switch gear for it.
I've not used any for a good while but used to use it regularly. Years back, we used to get single sleeved red + E, black without earth. Still got some in stores.
Reply to Second red 'live' wire in light fitting - what to do? in the UK Electrical Forum area at ElectriciansForums.net
As said, looked like there was enough cable slack to correct direct and avoid fitting the wagos in ceiling void
Thank you Thank you all done and working
