N
nickp78
hi, in the section of an EIC covering Particulars Of Installation Refered To In The Certicate which covers the Main Protective Conductors when filling out the part for the earthing conductor which in a domestic situation would be the copper cable from the suppliers fuse to the board MET, if you had a situation where you have 4 three phase DB,s which are all fed from a large radial circuit and you where adding an additional circuit to one of the four DB,s what would you enter into the section for earthing conductor, would it be the earthing to the large SWA supply cable or the earth as it enters the sub DB
