security light cable | on ElectriciansForums
Discuss security light cable in the UK Electrical Forum area at ElectriciansForums.net
when wiring a security light the type with mounting bracket, do you run the cable inside the bracket to the wiring box or outside the bracket ?
i understand that it depends on cable run but i usually try to run it inside the bracket to allow for adjustment.
Reply to security light cable in the UK Electrical Forum area at ElectriciansForums.net
There should be. Keep them all straight, insert two and then the third - don't twist them all together. If that doesn't work for some reason, use...
Of course, showing my age now!
