Security Light Problem. | Page 2 | on ElectriciansForums
Discuss Security Light Problem. in the UK Electrical Forum area at ElectriciansForums.net
Gillingham, Dorset
Ran a security light off a fluresent light in kitchen.
Used 4 port supply push in wire connecter.
Earth and neutral wires connected inline to existing terminal blocks.
When I turn "OFF" bathroom fluresent light after use, the security light turns on.
What's causing this please?
Thanks!!
On a different tack - might the security light be seeing light emanating from the bathroom?
It's presumably supposed to respond to IR from a person, and/or movement, but if it was detecting 'dusk' when the bathroom light goes off, might that switch it on?
Masking the detector should show one way or the other ?
The light is outside my kitchen door overlooking back garden.
Bathroom is some distance away.
Thanks for reply!
In the absence of many obvious answer
If everything is in order with the installation wiring and the new pir light wiring
I would be checking the switch terminals and probably checking if the issue occurs with an incandescent bulb connected at the bathroom
Seen something strange happen before switching off fluorescents
More than likely the answer is more obvious than that though
Reply to Security Light Problem. in the UK Electrical Forum area at ElectriciansForums.net
There should be. Keep them all straight, insert two and then the third - don't twist them all together. If that doesn't work for some reason, use...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
