• Please use style selector to select BLUE AND WHITE. If you are not already on it. This notice will go once you're on the correct style.
Seeking product recommendation for lighting control
We had our house built over 20 years ago and at the time - for a small number of rooms, I installed products from Rako Controlls.
These were 'in ceiling' wireless dimmers that controlled banks of 12 and 4 Tungsten downlighters plus a string of under cabinet LEDs running from an LED power supply (just on/off) using a wireless control panel (3 in different places) to control different scenes and/or simply dim.
Time has moved on, I changed most of the lights to LED and things have got a little less reliable.
I would ideally like a solution that meets the following criteria.
Controllable from a wireless keypad (several off)
Controllable via Alexa
In-Ceiling dimmer hardware
Dimmers capable of dimming 4 and 12 LED downlighters (currently Mains on GU10 fittings) as well as turning on/off an LED power supply that provides cabinet lighting.
Able to support a number of 'themes' - ie - all on, all off, all at xx%, one bank xx%, one bank yy%
Can anyone point me in the right direction of a suitable product?
- Richard
