Selecting the proper solar panel/ battery system for 12v LED strip | on ElectriciansForums
Discuss Selecting the proper solar panel/ battery system for 12v LED strip in the Lighting Forum area at ElectriciansForums.net
Colorado
Hi all,
Complete novice here, but I'm trying to learn.
I am making a solar powered, back-lit estate/ driveway entrance sign, and am stuck regarding the correct wattage, amperage, etc for the panel and battery.
I'm planning to use 5 meters of 12v 18w strip, but would like to be able to use 10 meters if necessary.
The idea is to use a photoelectric switch so that it will charge during the day and last 8+ hours at night.
Can anyone give me advice on the specs of solar panel and battery that might be needed?
TL;DR
Choose solar panel and battery combo for 12v led strip lights.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Hi
I do not suggest you to use the 18W LED strip light, you will have to use very expensive battery and solar panel to match it.
Instead I strongly suggest you to use 8-10W LED strip light with high lumen output, such as 150LM/W.
For the solar panel and battery, you should ask the solar panel and battery supplier to make the recommendation.
Reply to Selecting the proper solar panel/ battery system for 12v LED strip in the Lighting Forum area at ElectriciansForums.net
The charge controller takes care of all that for you amongst the other things it does.
Hi all, I have a couple of questions I'm hoping you can help with. I have put a solar panel on my kids play house which charges a 12v battery. I...
