selv pelv felv & testing of them (questions) | Page 2 | on ElectriciansForums
Discuss selv pelv felv & testing of them (questions) in the UK Electrical Forum area at ElectriciansForums.net
London
Hi all hope everyone’s well.
Sorry this a long read but I really want to get my head around this… simplified questions at the bottom of the long read…
I’m struggling to understand it as there’s not many videos explaining it and lack of diagrams in GN3. I’ve been through bs7671 section 414 and read through forums on here and the selv pelv pages on TLC but I’m scratching my head even more lol…
So selv would normally be supplied via a step down transformer which may power downlights for example but do not have a earth on the secondary side so you cannot get a shock if one of the conductors shorts to the metal part… These would be useful in zones 0 providing the transformer is obviously outside of zones and your typical downlights like jcc v50 outside of zones…
Then there is pelv, which does have an earth on the secondary side which can give you a shock,
Q1. What is the purpose of using pelv if you can get a shock?
Q2. Will the Rcd/rcbo operate if there is a fault to earth on the secondary side?
in section 414 it mentions about socket outlets being on a selv pelv system.
Q3. When it mentions socket what would be a a current using equipment on a selv socket?
Q4. Ceiling luminaire couplers are mentioned, where selv should only be 2 pin with no earth contact to separate from earth and from low voltage systems? As pelv is earthed then it would be 3 pin?
Q5. What is an example of felv and where would it be used? From what I read it’s not that common and BT use it?
Testing
GN3 Page 74
Insulation resistance testing between live conductors including other selv and pelv circuits
SELV table 2.12
Q6
. so you would disconnect the transformer or before it’s connected, you would put primary lives together and secondary lives together and test between them at 250v DC?
Q7. Then test between the secondary lives together to primary earth to make sure it is actually separated from Earth at 250v DC?
Q8. But it’s saying between other selv/pelv circuits so say if you got selv transformer in a bathroom and selv transformer in a bedroom are you then joining lives of the selv secondary side in the bathroom and lives of selv secondary sides in bedroom then using wander lead method to do IR test between as it will be a distance away?
PELV table 2.13
Q9.
Same as Q6? Q7 not followed as it is not separated from earth?
Table 2.14
Q9.
So same as Q6 and Q8 again but at 500v DC? Reason it’s now increased is because we did 250v before and it was clear so we increase to 500v and it’s not passing through the equipment but it’s measuring between the cables that should be separate?
Q10. Lastly you IR at 500v between exposed conductive parts on the selv side of the circuit? And between exposed conductive parts of the selv items and any primary exposed conductive parts and extraneous conductive parts to make sure it’s electrically separated from the earth?
Thank you very much in advance to anyone who takes the time to read and respond to these questions!!!
Yes so true and I tend to get caught up and spend way too much time on things and get side tracked from the main mission. You’re right, understanding the how’s and whys makes things so much easier the rest is a breeze. I managed to workout what happens with RCD testing from a couple good folks on here feels it feels so rewarding to learn
When I was at college doing the 2361 back in the 1980's I still recall to this day the instructor (Mr Wood) saying
"Lads I do not want you to remember that A goes to B" "I want you to know WHY A goes to B that is how you will learn this trade" such has served me well and as I say something I never forgot.
Reply to selv pelv felv & testing of them (questions) in the UK Electrical Forum area at ElectriciansForums.net
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
