Skrimgo
Hi there, after endless searching of the mighty interwebs with no solid results I've found myself here with a question or two.
If I were to replace the wiring for various ecu sensor inputs (such as the hot-wire mass air flow sensor for example) with thicker gauge wire, would the ECU still receive an accurate reading?
I would assume the answer would be the same for re-connecting a cut sensor wire that is the same gauge with a butt crimp connection. Would the ECU still measure accurately?
Bonus points for decent explanations, thanks in advance.
ECU in question is Nissan RB20.
