about 20kW - 23kW. as eng54 said. get an eletrician to asses the requirements. if you post your location, 1 of us may be close to you.
Discuss Separate supplies? in the DIY Electrical Advice area at ElectriciansForums.net
what you need to allow for is that everything will not be drawing power at the same time. unless you have some heavy stuff, like showers and cooking equipment,then 20kW is ample .
gas water heating does not use much electric power. it's the heating that consumes the most power either electric or gas.
power showers are the way forward. the ones that have hot and cold feed.. so you're not using 9kW to heat water.
electric hob will use a lot more power than a microwave. look at the rating plate to see the kW.
Tel I hope you get the job with how much information you have given to the op, you really are a Gent.:wink5::wink5:
Reply to Separate supplies? in the DIY Electrical Advice area at ElectriciansForums.net
