Seperate CPC | on ElectriciansForums
Discuss Seperate CPC in the Electrician Talk | All Countries area at ElectriciansForums.net
F
frankmac
Guys
involved in large project where there will be a few sub mains running ,from 50mm /300mm etc electrical engineer running the job reckons the armour is good enough earth and no seperate earth required.
Your thoughts Gents please.
[ElectriciansForums.net] Seperate CPC
having said that i can remember a large project where the consultants forgot to put cpc's on cable schedule
took about 3wks to pull them in after.ÂŁÂŁÂŁÂŁ
yours benji
As benji said, calcs calcs calcs, should have been done already before, but i know designers that anything above 35mm they run seperate cpc,s anyway, belt and braces, but eh! who are we, we only go off specs.
Reply to Seperate CPC in the Electrician Talk | All Countries area at ElectriciansForums.net
I'm assuming the cable will have to be cleated well to hold it in place anyway, as a stuffing gland ain't going to hold it tight like a SWA gland...
You would treat it as a TT installation.
