Seperate RCD enclosure | on ElectriciansForums
Discuss Seperate RCD enclosure in the UK Electrical Forum area at ElectriciansForums.net
leep82
Stoke on Trent
Ive recently been out to look at a kitchen refurb, where a split load mem memera 200 consumer unit is installed. The ring final circuit supplying the kitchen has 30mA RCD protection, no issues here. My issue is the oven supply. The OCPD is a 32a cartridge fuse which is on the non RCD side of the consumer unit.
The proposed work would involve the reposition of the old oven supply, utilising it for a new induction hob. This would involve chasing out into a wall and obviously the need for RCD protection. Im unsure due to the age of the board as to whether RCBO’s are available. With this in mind i suggested a seperate enclosure adjacent to the consumer unit to house a 63a DP RCD.
I would still be relying on the cartridge fuse for overcurrent protection in this setup, would it be better to install an RCBO in the enclosure? Just seems pointless to me.
Secondly does the enclosure need to be of metal construction? The consumer unit is of plastic construction and the suggestion of a new one to overcome the issues raised was pretty much flat refused.
Do you mean memera 2000?
If so the RCBOs are
[ElectriciansForums.net] Seperate RCD enclosure
Just noticed there, the rcbos on eBay are all sold as “used” so it’s a chance as to whether it works ok:confused:
A Memshield 2 will fit a Memera 2000 but not visa versa as the Memera 2000 has a narrower busbar tab. Strictly speaking they are not compatible due to the busbar size. True Memera 2000 rcbos were two module.
Personally i would get a small metal enclosure and bung a rcd in for the circuit you are working on. It does sometimes pay though to put a larger enclosure in so that in event of future works extra rcds/rcbos can be put in the empty enclosure for other circuits. prevents lots of 2 way boxes on the wall... as daft as it sounds larger enclosures are sometimes better priced than small ones???
Reply to Seperate RCD enclosure in the UK Electrical Forum area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
