Series parralell ? | on ElectriciansForums
Discuss Series parralell ? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Milton Keynes
Can anyone confirm my wiring for 4 x 120w panels, my controller is 50 v max, so im going this layout.
[ElectriciansForums.net] Series parralell ?
Do the panels have reverse voltage diodes fitted? They need to have to prevent one panel feeding back into the others.
What sort of controller have you got?
Good controllers are worth it as they do a better job of converting low output into usable voltage.
Reply to Series parralell ? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Whatever... I awoke this morning ready for an intersting and relaxed day at work at my local branch of the Men's Shed charity. " jobs pending...
You only need to switch the lines and the contactor is rated per pole so for example a 16A four pole contactor would be fine.
