Service Cable to sub panel theory question. | Page 2 | on ElectriciansForums
Discuss Service Cable to sub panel theory question. in the UK Electrical Forum area at ElectriciansForums.net
MdGNev
Nevada USA
Going to be running a sub panel underground 100+- ft to new steel building will be running a 2-2-2-2 Aluminum SER Cable. (Planning n 100amp svc even thought I doubt I will EVER need it.)
If the #2 SER Cable is
2 (+)
1 (-)
1(g)
Why am I running a ground all the way back to the panel?
Seems to me since I will need a rod at the building to ground from the sub panel, Couldn't I run a 2-2-2 Aluminum SER Cable 2+ and 1-
And meet the grounding needs for the sub panel with the local rod?
We have lots of different words for the same thing between USA and UK
Hot - live
Earth - ground
Sidewalk - pavement
Donkey - ---
--- - bum
Bum - tramp
Donald Trump -..........
Well you get the idea
Thanks.
I do think that your opening sentence is off course mate. How can my post not be true “at all” when your 2nd sentence repeats what I have said? adding your own spin, naturally. Just my opinion.
Ok, how about this:
It’s not the case that there must be a CPC, and that it has to be part of a cable containing the live conductors.
If it were the case, we would not be allowed separate tails, and we most certainly would not be allowed TT installations.
Reply to Service Cable to sub panel theory question. in the UK Electrical Forum area at ElectriciansForums.net
Hi All, Looking for some advice into my build. What I've basically done is add additional RCD protection to my 100% off-grid 12V 3300W Inverter...
The power company only brings in 3 wires which is 2 live and 1 neutral wire. It’s our responsibility to add the ground rod to bond the neutral...
