service interval timer help! | on ElectriciansForums
Discuss service interval timer help! in the Central Heating Systems area at ElectriciansForums.net
Ruislip
I got a virtually new Danfoss programmer out of a job that was having a new boiler and controls installed. I fitted it in my house as my programmer was not working. It now appears that the service interval timer had been set previously and the programmer has now disabled my boiler. Danfoss won't tell me how to reset it as I'm not gas safe. Does anyone out there know what I need to do? Thanks in advance!
That's normall only a soft reset. A full reset normally requires a couple of buttons to be held in while pressing the reset itself.
Doing a search it seems Danfoss have got this tied down I think you need to find a friendly gas operative or randomly try different button combinations until you crack the code
No probs.
thank you so much, this was handy after rining donfuss " doofuss" and they refused to help i own the unit and its nothing to do with gas but they would not help while i was locked down on covid.
but your instructions worked great thank you.
i had service april 2019 so it was due 2020 control panel locked out so i had british gas service check it for contract they took over but did not change clock on unit for service so now it was locked out 15 hot and heat and beeping.
but the new service date is now october.
so with your help i turned it off! fingers crossed,,
thank you.....
not buying doofuss again.
Reply to service interval timer help! in the Central Heating Systems area at ElectriciansForums.net
glad it was such a simple fix..... And good job the previous owners didnt take it with them
Yes, gravity mode is not used much now, (thank goodness) it was for old systems where the hot water from the boiler convection circulates to the...
