Service point in out building | Page 2 | on ElectriciansForums
Discuss Service point in out building in the UK Electrical Forum area at ElectriciansForums.net
Fife
Hi there.
My friend is building a new house. He has decided to put service point in and out building next to new house. A duct has been run from out building to house. I will be using 16mm three core to supply house db. I've decided to use rcbo's for circuits in the house. But I am unsure if the cable at the out building side should be rcd after the cut off to supply the house? Any advice would be appreciated.
MP: Shoe box?
TG: Aye.
MP: You were lucky. We lived for three months in a brown paper bag in a septic tank. We used to have to get up at six o'clock in the morning, clean the bag, eat a crust of stale bread, go to work down mill for fourteen hours a day week in-week out. When we got home, out Dad would thrash us to sleep with his belt!
GC: Luxury. We used to have to get out of the lake at three o'clock in the morning, clean the lake, eat a handful of hot gravel, go to work at the mill every day for tuppence a month, come home, and Dad would beat us around the head and neck with a broken bottle, if we were LUCKY!
I would use 2 core 25mm swa and a separate 16mm earth. Terminated in a metal clad box (or plastic with 32mm knockouts) feed it from a 100A main switch there to an adaptable box (again with 32mm knockouts. And then supply your board as normal with meter tails from the adaptable box.
Or use 3 core swa and leave one core a bit longer so it will go from the earth at source (tns) to a met at the db. Would look something like this in the end.
[ElectriciansForums.net] Service point in out building
As it's TN-S you don't need to do ^^^. The Cu Equiv. of the armour should more than meet your adiabatic.
No overload protection for the sub main then?
Reply to Service point in out building in the UK Electrical Forum area at ElectriciansForums.net
When he bought the bank, they stripped out all the metalwork, iron bars etc for scrap. He was left with the cashier countertops… which have been...
  • Locked
I'm not sure where this thread is going or what you are demonstrating is by an electrician or yourself. It doesn't really matter as the forum...
