Settle this Argument. | on ElectriciansForums
Discuss Settle this Argument. in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
metal faceplate 1363 socket. obviously needs to be earthed. argument is whether the back box should be earthed just because it's a metal faceplate. ( i know it's considered good practice to fit a fly lead anyway, but that's not the argument. the argument is with the faceplate being metal, does that make any difference. my argument is No, other party says Yes. Who is right, going by BS7671?)
I would agree with you.
Perhaps if the back box was exposed such as surface clad metal boxes then I would fly lead to the back box as well, only because the back box is more accessible to touch than in a wall if the socket face plate was ever removed for testing etc the back box is still earthed.
You can argue it's the same thing I suppose.
I can't see what difference it makes if the faceplate is metal or plastic myself. So I agree with you.
Incidentally, I have noticed that the practice of earthing metal backboxes seems to be dying out, along with doubling over smaller conductors (especially CPCs).
I was on a facebook sparkies group and doubling over was brought up. All the younger guys chimed in "You don't have to do it with modern terminals" Clearly some garbage they are repeating in training centres. This was about an 80% consensus.
My 20p - both need earth, from reg 411.4.2 which in part says "each exposed conductive part". But is a recessed metal back box an exposed conductive part, or is maybe deemed to be ?
GN 1&8 suggests that it's an exposed conductive part and is part of the enclosure for the wiring accessory so should be earthed
Though I don't disagree with bonding the box, I cant see how a buried boxed is classed as exposed? I think its a grey area, which is simply covered by over kill bonding that is simple to install & unobtrusive any how, so why not fit it.
the back box is earthed anyway by the 3.5mm faceplate screws until or unless the faceplate is removed. in which case, the circuit should be isolated first.
I mentioned this way way back during conversation with an inspector. He said though this is true they cannot be relied on for bonding purposes therefore the back boxes should have additional bonding.
Yeah the text book answer is that the socket would be isolated before removal but we all live in the real world and sometimes you need access to the terminals for any live testing or for fault finding etc.
Plug in testers are not a way in proving dead as far as I'm aware tho we all use them I'm sure.
Not forgetting DIY decorating when the faceplate is pulled away from the wall for papering or painting.
Reply to Settle this Argument. in the UK Electrical Forum area at ElectriciansForums.net
Many thanks all. Very helpful to be able to bounce these things around. Was fairly happy with it all initially, but once the seed of doubt is...
Don't need to read again the picture tells me what I need. BTW your a bit touchy about solar, it's old hat these days 🤣 and a waste of money
