Shading sun path viewer | on ElectriciansForums
Discuss Shading sun path viewer in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
R
Ramjam
Hi,
I'm looking for a sun path shading viewer thingy. I saw one a while ago which had a digital camera mount which seemed like a good idea but I can't find it again. If you've got such a thing do you think it's good?
I've used it a few times mainly on jobs which had shading issues and the customer was insisting on a poor location so really it was used to deter them from that and to show them a better alternative
I can see some installers not liking these devices as it can sometimes have the opposite result and the customer decides its not that viable
on the other hand it can show that you are a responsible installer who won't fit it just for their own gains
the model I've used has a perspex dome under which you place a sun path chart specific to latitude you level it align to compass bearings and when you view it you get a fish eye view showing the horizon and any objects causing shade , you then trace arond the shaded areas and add the numbers together this gives you a percentage of shading throughout the year, its looks hard but is very simple ,you can also get a software program to present the findings ,I'm not too fussed about this and probably won't get it but the device works well and its easy to show the customer how it works
there is a video on it on you tube.
I looked at the video and it certainly seems to look good. The problem I can't work out is how you'd use it at roof height to get the actual shading, say 20feet up!!??? Or do you do it at ground level and just ignore the possible difference?
Made a small platform for it and did it from eaves height with a roof ladder , and the other had a flat roof dormer i sat on, but yes it is a drawback , do it from ground level if obstructions are further away ,but if they are fairly close doing at ground level makes it appear worse than it is
but any device is difficult to use at eaves height,especially off a ladder except for the sun eye #1500 quid which you would do from a roof ladder
If you have an iphone take a look at the 'sunseeker' app. it has a flat compass that shows the rise and set points.
It also has a real time viewer that is superimposed on the camera screen to show you the sun path at both solstices and the day that you are viewing on. Shadow points are highlighted.
Very cheap at about ÂŁ4 (plus the price of an Iphone contract)
Not only is it a very easy to use and instant solution, it looks great-what a gadget.
downloaded the iphone version - looks very comprehensive and the date/sunset times is valuable in itself. But not sure how to use either the flat or 3D compass - it all seems backwards (or my iphone is completely inaccurate). But worth persevering with since it only cost ÂŁ2!
Reply to Shading sun path viewer in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Merry Xmas to all :D
Personally it would annoy me having to use adaptors all the time. Can't you buy a proper UK one?
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
