Discuss shall i test Fire Alarm in PIR? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yes test the fixed wiring for the fire alarm and emergency lighting when doing your PIR exactly the same testing procedures are required.
thanks sintra.
So i assume i need to test every part of the circuit including heat dector part which is low DV?
Reply to shall i test Fire Alarm in PIR? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
