Do you know why the armoured cable is going in plastic trunking?
Discuss shed consumer unit in the DIY Electrical Advice area at ElectriciansForums.net
He just said he will run it through plastic trunking to makeit look nice….
ok.
I understand you having doubts if last time you got shafted.
All depends mate. Its hard to say exactly over a forum, without looking at what he is doing. Regs say not more than 37 meters, so I cant advise on "roughly 38m give or take a couple or metres". It's the same as I can't say to you it's ok to drive 31mph in a 30 zone.
The way the electrician has recommended seems ok as long as he follows the regs. (CYA.... I'm good at that)
The job is probably okay, to get over the problem reduce the breaker size, job done.So do you feel that what he has offered is good enough? and seem legit?
Regards,
GSC
...He has said that what he wants to do is:
In my existing CU I have a spare slot next to my MainsSwitch, where he wants to connect the RCBO via the a Busbar. Then run 6mm2 3Core Armoured Cable to a length of roughly 38m give or take a couple or metres.From there the cable will fit into a Garage/Shed CU via an RCD which will have 2MCBs connected. One for lights and one for power sockets.
Looking at my equipment and lighting needs for the shed andgarden, he doesn’t feel I will go over 6KW of power usage at any one time andfeels that what he has stated will be ample...
Sounds just fine. If the final circuits in the shed are, say, a 20A socket circuit and a 6A lighting circuit, the VD in the distribution circuit (SWA) can be based on a max load of 26A. In practice, you won't notice or care if the VD is on the limit for lighting (it's only a shed!).
I'd query why he's using an RCD in the shed as well as the RCBO at the supply end. Might as well just fit an MCB at the main board; no need to RCD protect the SWA whether buried or not (unless TT supply).
Reply to shed consumer unit in the DIY Electrical Advice area at ElectriciansForums.net
