shed light - IP rated? | on ElectriciansForums
Discuss shed light - IP rated? in the Australia area at ElectriciansForums.net
Q
quickspark
hi guys,
i want to fit shed light and use this job for niceic assesment. i am not sure what light fitting i should use, shall it be ip rated for dampness or something? what would you recommend?
thanks a lot
Reply to shed light - IP rated? in the Australia area at ElectriciansForums.net
Thank you... I'll get up there have proper look, this was just a 1st glance !
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
