Shed lighting and Outdoor lighting Help! | on ElectriciansForums
Discuss Shed lighting and Outdoor lighting Help! in the Australia area at ElectriciansForums.net
C
chrisgc
Hi all,
My brother has asked me to install the following at his work place yard:
INSIDE of SHED at the bottom of yard:
Install 1x Twin socket (these sockets will mainly be used to plug an extension reel into)
Install 2x Fluorescent lights
OUTSIDE OF YARD ATTATCHED TO TIN ROOF:
Install 2x Spotlights
Replace 4x damaged Fluo lights
At the moment he does have a CU inside his yard office BUT as of yet no CU in shed.
Should I just run everything off existing CU or would it be a case of Installing a new CU in shed etc.
I have just passed course so he is kindly giving me the oppurtunity to price up and install as my first job - so just making sure I am not taking on to much that I can handle.
If someone could give me a bit of a walkthrough list of what would be the best way to tackle this then I would be very grateful.
I look forward to hearing from any of you good people.
Chris
you could run a 5 core swa out, then you have provisions for lighting and power, using the CU in the house. you could then put an isolator in th shed but you would't really need to. or just put a small 2 or three way CU in shed with its own RCD, this can also be the main switch for this CU. SWA size? say...4mm or so
Reply to Shed lighting and Outdoor lighting Help! in the Australia area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
Heh I know the brochures for courses with stock images of women using tools in random scenarios but when you're there it never happens, it's all...
