Shed Power info needed. | Page 2 | on ElectriciansForums
Discuss Shed Power info needed. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Without knowing the full installation it would be hard to say but RCD FCU in the house then the whole cable is protected.
Socket outlets are on RCD protected in the main CU.
So will 4mm SWA be sufficient for outside cable?
Reply to Shed Power info needed. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
