Shed power | Page 2 | on ElectriciansForums
Discuss Shed power in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
about 30 metres in all think they were going to connect into outside socket that is were i found the end of cable under the patio next to the outside socket
Even though the swa has 3 cores make sure that you earth the armouring at the house CU, doesn't have to connected at shed end .
Is the shed completely wood or is there metalwork involved, is there a water or gas supply to it?
Is it ok to export the earth 30 metres or should the shed have an Earth rod?
Reply to Shed power in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
Do you know what percentage of scheme registered electricians are registered to sign off 3rd party work? Even better would be a poll of how many...
nicebutdim
N
