Shed supply from new build property | Page 2 | on ElectriciansForums
Discuss Shed supply from new build property in the UK Electrical Forum area at ElectriciansForums.net
England
Hi guys, as the title suggest. Friend of mine buying a brand new house from a reputable and well established builder. however it has already been 1st fixed.
He\asked the builder if he could have an U/G supply taken out to the detached shed. Yes they could, no problem.
Method. To tap off the kitchen ring final circuit.
I would of thought a separate circuit from the house consumer unit would be required.
Is it still acceptable to tap of the ring final circuit? I know it used to be done that way years ago.
Thoughts please.
Reply to Shed supply from new build property in the UK Electrical Forum area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
Adding a led strip isn't going to make much difference to the 3 phase balance. No real difference to where a 3 phase machine uses one phase to...
