Guest viewing is limited
View the thread, titled "shed supply" which is posted in Australia on Electricians Forums.
dave-gardiner
oh no not again.
shed is 100M away. 13 A load.
plastc conduit.
mcb in house 16A type b.
6mm live and neutral thru conduit (plastic) to shed. then earth rod to make TT system and finally rcd in shed. is this ok?
Freezer all that distance away, sod that.
If you are doing the job and being paid per hour, and its PVC conduit, make sure you carefully glue each and every joint.
Stretch it out, then see what they have to say about the cost versus you putting SWA down!!
Your customer is going to have a Freezer 100 metres away from the house?? Well that makes a lot of sense then!!! lol!!!:shocked3: :lipsrsealed2:
So what's the depth has this PVC conduit been buried too?? You could to get a fair bit of condensation in that pipe, another problem with using conduit, especially over long distance with no openings and little or no means of air flow!!
Reply to the thread, titled "shed supply" which is posted in Australia on Electricians Forums.
