Shillitoe parish community centre
C
cryoservice1
Hi there
has anyone got any info on the Shillitoe parish community centre project for the 2391-20 or the old 2400 got some figures down and some ideas on paper but would like to know what others have put down so that i can confirm my findings.
    • i have put two extra boards on the ground floor one in the staff room and one in the store opposite to the toilets
    • i've used dado skirting as my wiring system for the supplies to the s/o as in the spec it states that the floor coverings are already down
    • i got a figure after applying diversity( + 10% (for future additions) of 659A, across each phase 220A for the maximum demand
    • havent done anything on the pv supplies apart from what the question asks ie. suitable systems and manufacturers data
any help would be greatly appreciated
Thanks.
I'm currently doing the 2400 course and will be the last to do the Shillitoe parish community centre as the project as it changes in October from what I hear..... Just looking for some advice i.e the power correction factor for lighting via electronic ballast is 1.8 but looking at manufacturers data sheets power correction isn't as drastic, can you select light fittings attach manufacturers data and base calcs upon info provided? Also did many of you find that a 2nd DB was required for the groud floor to minimise the volt drop in the final circuits? And PV arrays I've never dealt with those before where do you start!?
If anyone has any old info based upon old projects they could send me it would be much appreciated ([email protected])
Upvote 0
Electrical Courses
