Evening all
Moved into the new house yesterday and started out by installing the heated mirrors in the bathrooms.
First one went without a hitch because we had the builder put in switched feeds to each of the mirror positions.
The mirrors are plain cut ones each with an adhesive demister pad on the back which are then wired to the live and neutral.
As we moved the second mirror into position I touched the metal tile trim which runs around the recess for the mirror with the same hand that was holding the mirror and got a shock.
I’ve checked all the wiring and all seems fine.
Any ideas or I do I need to call in the professionals??
