Short when light turned on sometimes | Page 4 | on ElectriciansForums
Guest viewing is limited
Discuss Short when light turned on sometimes in the UK Electrical Forum area at ElectriciansForums.net
A
aaelectric
We have been doing work in a flat where we had taken down light and put a temp ceiling rose. All was fine for a month then we fitted new expensive chandeliers. Worked fine for a few weeks then on some mornings the circuit would trip with a bang. Went back did a ir test all was clear 10m ohms between n-e l-e. Tested light that it was blowing from all was clear. Left off for a few days no problem. Refitted it and after a week it starts happening again. Light supplier says it carnt be the light as it would not cause a short. Any thoughts it run in singles in conduit.
As an apprentice I got lumbered with “Larry” as a mentor. It didn’t last long, he insisted on using Screwits. Even as a youngster I knew they were crap and refused point blank to use them.
Larry reported me to the foreman who came to the workshop, I was expecting to be given a rollicking. He helped me chuck every single Screwit in stores in the crusher. We even emptied Larry’s tool cupboard of them.
They were a disaster waiting to happen from the outset.
I wonder how many electrical fires there are in America? They’re very fond of wirenuts.
I also hate the blooming things! I've come across them in conduit boxes and most of them fall off the cables when disturbed which explains why some were taped on as well. I'm guessing the ones that are currently available are made of plastic as I've only come across the old ceramic type.
These were found by a friend if mine a while back. [ElectriciansForums.net] Short when light turned on sometimes
Did you work with Larry as well? A screwit and tape was his method.
Reply to Short when light turned on sometimes in the UK Electrical Forum area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
Recommended Sponsor News
Hi everyone,
