Should I carry out EICR the change DB | on ElectriciansForums
Discuss Should I carry out EICR the change DB in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
london
hello guys
Just want some advice as a landlord has sent me some pictures and the board defiantly needs changing and they want an EICR.
Am I overdoing it by carrying out an EICR with a fuse board to be changed which will get an install certificate or am I just sensible to carry out the EICR and have a board change as part of the repairs?
I only ask because they will get an install cert which could override the EICR once I change the board although an EICR is more sensible because I won't have any supprises once i change the board (should not).
personally i'd do a few tests first any way to make sure there's no surprises once RCD/s are fitted. also check and test earthing/bonding. then do the necessary and issue EIC. ( unless the landlord specifically requests EICR/landlord's safety cert.).
In such cases , and if I'm happy to go ahead with the change I do the EIC for the cu change then my software allows me to create the EICR and do the additional comments etc
So it's more time and money for the client, but less than 2 separate jobs.
The landlord is currently asking you to do an EICR and as of yet not change the board, you are deciding a board change from some pictures is this correct?
hello guys
The OP does suggest that a CU change will be part of the job ....
so its an EICR and a EIC ........ and depending on how you approach it, maybe another EICR..............
Reply to Should I carry out EICR the change DB in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for the reply littlespark. Yes the works have been carried out. Surely it is fraudulent because basically the document is Not...
I tend to write the circuit number on the mcb say every 5th mcb/rcbo just to help make it easier to locate in a large multi way or 3ph board...
