Hello,
I have a generator that generates 14V/20A DC for two ends and I use both of them for operating olive harvesting machine.
I have no Idea how much wattage or Amp each one needs because it came off the label , but I know that they both need 12Volts each.
The issue : operating both on the generator makes it struggle a bit..(slows them a bit). In general I have noticed that each of the appliances came with different wire thickness, I am considering changing the one with the thinner cable to a thicker one so both runs smoothly on the generator (goal - maximizing use of generator electricity )
A bit details:
Cable length for each one is about 10 meters long
Generator gasoline one.
Olive harvest machines Detail (assumptions based on common ones) :
16-20 Amps
12Volts
150-300 watts.
Would changing the wire make big difference?
The machines are from different brand, maybe one has smaller motor than the other (I really can't find that information)
My whole purpose here is some what to eliminate the speed loss for both harvesters when operated together , somewhat eliminate the voltage fluctuations from the generator.
Anyone helps thanks I appreciate it very much ?
i would suspect that running both together is overloading the generator. what is the rated output (in watts or amps) of the generator?
Hello thanks for you help, I have no appropriate tools to measure it.
But as I stated, it give 20Amps for each connection as written on the connections.
I think too it shouldn't be a problem but still it slows a bit and I think I can help make it more efficient?
If the generator is slowing down then, for whatever reason, the engine cannot keep up with the electrical demand.
This could be because the generator does not have the output power to run both machines, or the engine could be due a good service or something else I haven't thought of.
The fact it has two sockets rated at 20A on it doesn't necessarily mean it can deliver 40A, or deliver it continuously.
The generator was serviced not long ago.
so should i thicken the wires to help it consume more electricity? To the machines?
As above mate. The thickness of a cable does not determine how much it draws. The ratings on cables are how much current the cable can draw safely. A 0.5mm cable will still draw 20A but it will not do it safely. It will overheat until it malfunctions.
Hi - as above, if you increase the size of the cables it likely won’t make the generator run smoothly. If the generator and machines run ok but only one at a time then it’s likely the generator is (for whatever reason) not up to the task. This might be confirmed with some simple tests if you have a suitable voltmeter (?)
Thanks All for the responses.
Today I checked the voltage it run between - 11-14.5 Volt.. (of course because it's a gasoline it won't be steady stream) wasn't able to check amps because my multimeter limit up to 10 apms
I thought for a second that increasing the thickness - lessen the resistance and as a result will give the machine the whole 20A that the generator provides?
The appliance will come with the correct cable fitted.
If you run each appliance individually everything is fine.
When you run both appliances at once, the generator struggles.
I'm afraid you are going to have to buy a separate generator to run the second machine
If the cable is too small then the most noticeable effect will be that the cable gets hot whilst in use, also you may see the machine running slow, but it won't normally make the generator slow down.
You can try bigger cables, but if the generator cannot provide enough current it will make no difference.
Hi - so it sounds like 14.5V is when the generator has no load (please confirm) and 11V is when both machines are loading it?
Can you tell us what is the make and model number of the generator?
All I know : is a Chinese made generator /japan.
Properties
Output: Single phase 230v
Frequency: 50 Hz
Continuous power supply 230v: 850w
Maximum electrical power 230v: 900w
12v socket for charging batteries: included
Weight: 26 lbs
Noise from 7 meters: 75 decibels
The engine
Engine volume: 80 cc
Engine Speed: 3600 rpm
Engine Model: A154F
Cooling: Air cooling
Fuel tank volume: 5.5 liters
* I really don't care about the spinning of the generator.. All I want is both harvesters to Not slow - and they do.
If each one is about 300 watts, it should run really fine but that's not the case, I Am not saying it slows to a level that you can't work with, I am saying that working with only one connected is way easier and faster (spins in the right amount- not too fast not slow) but when connecting the other one.. It really slows down to a point I guess its slower than it should run normally
Increasing the generator running speed is not effective to my guessing because it makes a lot of noise and consumes more gasoline?
If you send me the make and model number I will look at its specification.
Without looking, I assume the maximum dc power available is between 12 x 12 = 150W and 12 x 20 = 240W which is considerably less than that available from the 230V ac output sockets - 850W
What I would do is power the olive machines from the 230V ac outputs which would provide circa 425W to each olive machine. Also, lower volt drop along the long runs between the machines and generator.
You could buy for each olive machine a power supply which converts 230 V ac to 12V dc at 20A continuous (60A surge) (240W). Or - maybe cheaper to do - buy a 12V 20A battery charger and connect it to a 12V lead acid battery; then connect the olive machine across the battery. The nice thing about using the charger and lead acid battery is it provides a more stable 12V output using cheaper components and increased surge current for when the olive machine starts or has to work harder. All the gennie is doing is charging the battery.
You could have the one battery charger and battery for each machine, or one 12V 40 A battery charger connected to one 12V battery (and if possible a bigger Amp-Hour capacity). The problem with this scheme is thick enough and short as possible cables to carry the 40A between charger and battery and 20A to the machines. If the average load is greater than 240W then the battery would be discharging.
If you can afford it the best scheme is a battery charger-battery (eg car battery 100Ah) for each olive machine and located close to it.
Please let me know with some pictures what you end up doing. Keep the charger and battery out of the sunshine and heat.
SAFETY - even though the 12 Volt side is safe to touch, there is the possibility of very large short circuit currents to flow which can cause dangerous arcs, plasma and very, vert rapid heating to red hot in wires. You must put a fuse or circuit breaker in the positive(red) cable to the battery plus terminal and cover the terminals so that exposed metal cannot be accidentally shorted together. A suitable size fuse or circuit rated would have a rating of 100 to 150 Amps and rated for low voltage. If you are stuck for where to buy them I will pass you details of companies in the UK.
If the olive machines are not run at 100% capacity all of the time then you could try first of all taking the 12V dc gennie output to a 12V battery ( suggest 2 x 100Ah in parallel) and connecting the machines across the battery. This scheme would work if the total average load of the olive machines is 240W because this what the gennie can provide. if the average load is greater than 240W then the battery will be discharging to make up the difference.
Hello Dear,
Thanks for your help, I didn't understand the charger - battery thing I am sorry... ( but I understood the the battery should be connected with the generator.. And then the battery will give constant current to each machine)
You say that I should connect both machines to the AC output? And they should run better on the generator? Without slowing the spin? *note that there is only one AC outlet.
I attached generator image.
Let us proceed in stages. Obtain one 12V car battery (say 100Ah) and connect it to one of the 12V output of the generator using thick cables. Connect one olive machine across the battery and see how it performs. Then connect the second machine across the battery and see how you get on with two machines working on one battery charged by the 12V output of the gennie. Remember the fuse or circuit breaker - OR BE VERY CAREFUL NOT TO SHORT CABLES. Connect red(+) to red(+) and black(-) to black(-).
If you can, charge the battery up first for 4-5 hours unless you are certain the battery is already charged.
Post a picture of your set up and also a picture of a match against the side of one of the cable so I can guess what size cables you are using.
DO NOT CONNECT A BATTERY OR OLIVE MACHINE DIRECTLY TO THE 230v BLUE SOCKET SUPPLY.
Marconi i appreciate it very much your help!
But, you know battery makes things more complex and less convenient it's heavy! (i did connect the machines directly to the tractor's battery and they worked pretty good)
Why not connect battery or machines directly to the AC outlet? Because of the volt big difference? Might explode..
* but don't you think that the machines had a regulator/volt adapter?
I really thank you for your help ! Don't be turned down by my response
There are three reasons why you must not connect the 12V dc olive machines directly to the blue 230V ac sockets.
1. The voltage output from the ac blue sockets is 230V and your machines require 12Volts.
2. The electricity from the 230V blue socket is alternating current whereas your olive machines require direct current.
3. Your olive machines are only electrically safe to use when supplied with 12Volts.
So, banish the thought from your head about connecting the olive machines directly to the blue socket.
To power the olive machines using the blue socket you would need the 230V ac to 12V dc converter/battery charger I metnioned earlier.
[automerge]1572175118[/automerge]
Car Battery Charger -50AMS | Konga Online Shopping - https://www.konga.com/product/car-battery-charger-50ams-3641553
Here is an example of a battery charge which is powered by 230V ac and outputs 12V dc. The single red and black leads are connected to the +(red) and -(black) of the 12 V battery and the 230V plug is put into a socket. This is one is not good enough for your job.
Ok got it.
Just let me clear things out..
Why eventually my generator not giving enough power? Is it due to the lengthy cables or because of the varying voltage out of the DC ports (which runs between 11-14.5 volts) ?
Or is it the quality of the generator itself?
Thanks in advance
Ok got it.
Thanks in advance
Most likely the generator is too small to give enough output power. There doesn't seem to be a power rating for tbe DC output, but since it is called a battery charging output I very much doubt it is capable of providing a lot of power.
Your generator is actually two generators. One outputs 230V ac and 850Watts and the other 14V dc at 20A which is 12 x 20 = 240Watts. The maximum power out of the 230V scoket is 850 Watts. The maximum power out of both 12V terminals is 240W (ie 100W from ones on left and 140W from one on right). Total ac and dc power is 850 + 240 = 1090W.
The generator struggles to power two olive machines because their combined power requirement is more than the 12V generator can provide, so they slow down the generator a bit which reduces its voltage output which reduces the power consumed by the olive machines motors which reduces the current flowing between the generator and the olive machines until the ability of the generator to supply power - its lower output voltage times the current is equal to that consumed by the olive machines. In electrical engineering this is called droop - the lowering of output voltage with increasing load for a generator, and the lowering of output power of a motor as its input voltage reduces. If possible the motor and generator interact through their individual droop characteristics to find a point of equilibrium where torque times speed of the generator = torque times speed of olive motor.
With regards to the length of cable - it takes energy to move electricity along wires and this energy appears as heat - the wires warm up. So if you put int X amount of energy at the supply end of the wire you will only be able to use X-Y at the load end were Y is the heat loss I just mentioned. To keep the the heat loss small the wires should be short and thick. This is especially important at low voltages such as 12V because it takes larger currents to move energy than at a higher voltage. eg: 12Volts x 10Amps -= 120Watts could be moved by 120Volts at 1 Amp since 120 x 1 = 120W.
The amount of heat loss depend not on the current but the current x the current. So in my example, the heat loss depends on 10 x 10 = 100 not 1 x 1 = 1 which means the heat loss in the connecting cable at the lower voltage of 12V is 100 times greater than at 120 V.
Wires have a property called resistance R which is a measure of how difficult it is for electricity to flow. Short thick wires have less resistance than long thin ones. The power lost in a wire is the current(I) x the current x the resistance IsquaredR = I x I x R.
Hi - just to add to @marconi reply, it’s very likely your existing generator has the 12V capability for standby battery charging and it’s main game is generating 230V AC. That said, they do make generators specifically for 12V. These typically have 50A or more capability and are based (cheap ones anyway :) ) around automotive alternators. And as per M’s post are intended to work with battery storage.
I like the idea of running one machine off the generator’s 12V output and the other via the 230V output and a battery charger.
What a forum - someone is now getting advice on olive harvesting techniques! Nice one Marconi :-)
Thank you DPG. The line of thought is: London Underground had/has a problem with sweltering heat in summer on its platforms and in its trains , and like most companies wants to reduce its electricity consumption. So it took a long, hard look at the types of dc motors which propelled its trains and decided to ......?
Thank you DPG. The line of thought is: London Underground had/has a problem with sweltering heat in summer and like most companies wants to reduce its electricity consumption. So it took a long, hard look at the types of dc motors which propelled its trains and decided to ......?
......harvest olives ??
Carry on using 50 year old trains to make the ride as rough as possible?
Signed
A regular user of the Bakerloo line.
Signed
Patience - your day will arrive after which you will travel in some modicum of improved comfort. Anyway, I think a man of your calibre and curiosity would be easily pre-occupied thinking about things to worry little about some brief temporal discomfort.
Permanent magnet motors(PMM). I was wondering whether there are any PMM powered olive harvester poles which would be more energy efficient than those the OP uses now - and thus consume less power and current at 12Volts dc.
Noting your need for convenience, you could but the battery(batteries) beside the generator (on a wheeled cart).
Please keep us informed on what you do to improve performance.
Dear Shadyabs,
I managed to find a telescopic olive harvester which uses a permanent magnet motor running off 12V and a car battery (80-100Ah). This one will be more efficient in the way it uses electrical energy and converts it into mechanical energy to agitate the olives. It is also more powerful (500W). You may/will still need to connect your generator to the battery to maintain performance if you operate the machine all day - it all depends on how long you use the harvester for. If you used this PMM machine you would need a battery for each one because it draws about 40Amps. Then again, a more powerful motor may do the work of your current two in the same time or less.
Brumar Magiko 4x4 Telescopic Olive Harvester 8033655482008 | eBay - https://www.ebay.co.uk/itm/183572481738
Israel
All Other Countries (This Is English Speaking Website Only - WE don't mind Google Translate Users :)
Should I change for a thicker wires?
Electrical Appliances & Whitegoods Forum
Thread Tags
Shadyabs,
marconi,
