M
I wondered about that - there are 9 houses including my own on the drain run, all with vented soil stacks. There is (just) 1m from the toilet to the underneath of the extension roof, so I could possibly put an AAV under there - of course if shading isnt really an issue with the stack then I wont bother.hasn't this has come up before? Thought that one every 5 houses is required as a vent so you may be able to cap it below the level of the gutter
......... It also states air-admitance valves should not be used external to the property or in dusty areas.
Cut the vent off altogether and cap it, you've wrecked the external appearance of your house with P.V on the roof, don't worry about making it smell as well.
i got it!!!! cut it off and cap it yeh, then use your fit payments to hire a portaloo that way it wont smell and no shading jobsa goodun
If that pipe effects it that much, Im now convinced that all this PV is a load of crap.
and your contribution to reducing your carbon footprint is?.................
If I had the right of complaint tho' I'd object to P.V as being currently fitted.
Flush with the roof line, yes, O.k.
Its not "in your face" to look at.
My nearest neighbour at the rear (looking at my house) is 850 yards away. Hardly in their face.It's in your neighbours faces.
I see you're a seller of Solar then.
I assume you have a roof full.
Have you tried asking all your neighbours who can see your roof their views on what it looks like, you'll be surprised how many are not impressed with it.
without putting an AAV on?Only thing of note on vent pipes is if you have a WC in the attic space as you might with a loft conversion or a bungalow conversion. Top of soil pipe should be above top of WC pan so if whole thing blocks up, you don't get jobbies spilling on to the roof. (seems its OK to spill them in to the bathroom).
You will have to have bad drains to get bad odours from a vent pipe. Get up a ladder and have a good wiff. More likely to get a smell in winter when contents of flush are warmer than the outside world.
In general we shorten pipes where possible.
