Should rewirable fuses be pensioned off? | on ElectriciansForums
Discuss Should rewirable fuses be pensioned off? in the UK Electrical Forum area at ElectriciansForums.net
oracle
Kent
The 3036 re-wireable fuse link was invented long, long, ago, but according to the standards list became a BS standard about 1957.
Tried and trusted in standard form, it has probably been the most abused electrical component, with wrong fuse wire, paper clips, hair clips, copper wire etc fitted.
Yet even the 18th edition includes tables for them. Let's take this poor old, badly abused fuse and put it into retirement. Like the ghost of Christmas past it's past its heydays.
I'm sure the government will pay to have them all changed.....
You cant account for stupid and dangerous people using the wrong fuse wire or using an old nail. They are simple and made well for its intended purpose.
most of the older stuff is made to last and in my experience outlasts a lot of the modern stuff that seemingly goes wrong, I am not going to say they purposely build obsolescence into the things like mcb's etc.. but they are mass produced and at lowest possible price. Its inevitable when you make thousands of the same thing on a production line in the far east that failures will come through.
Beyond a fuse wire going I cant think of a time I have had to replace a rewireable. mcbs, rcds etc, I have had a few that have needed replacing, some have been product failures but normally its due to incorrect termination causing the case to melt at the terminals.
What’s the rating of smoke paper in a plugtop and maybe some tinfoil still come across this in older peoples property have found nails in 3 phase boards
If someone wants to circumvent a mcb they just put wire from top to bottom of tripping mcb only seen this once but still there you have it nothing is foolproof
Personally, I think yes they should be taken out of use. Apart from the problem of anything being placed in the fuse holder, there are other problems. The tendency when the fuse blows and wire replaced, which is really insanely fiddly, with a torch often, to replace the holder under load and get another blow out when inserted. Quite dangerous I think. Often missing covers which may constitute a fire risk. I think elderly people may struggle to pull and replace the fuse, an MCB is so much easier.
A good question Snow !
My very non scientific internet audit has revealed only one pic of a heat damaged one, compared with well more than I've fingers and toes of MCB variety.
Here 'tis :)
[ElectriciansForums.net] Should rewirable fuses be pensioned off?
I did say they were tried and trusted correctly used. Problem is, people seem to be determined to find any way to defeat the very things designed to protect them.
The worst examples I have seen is a suppliers BS 1361 cartridge fuse replaced with a short piece of pipe
Another guy used the 16mm earth conductor to connect the supply from the intake supply to the CCU main switch, bypassing the meter
Reply to Should rewirable fuses be pensioned off? in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
