**Show Us Your Installs!!!**
Spudnik
Right chaps,
Due to a few unavoidable issues, we have lost the original thread and pics etc.
Sorry about that!!!
So, if you want to re-upload your pics then great, if not, give us something new!
Cheers!!
You're right about the eddy current issue. They're cut lines not pen marks. However, the lockrings on the stuffing glands are steel. I mentioned it at the time but was told it's not a problem. I think it is though and would have preferred to have been using nylon / PVC stuffing glands. Again, I was told to just use what I was given and not keep asking questions!
You were right to raise the issue. When the Genny is running, those locknuts will heat up, in some cases they can go cherry red! This can cause the sheath on the cable to melt, and expose copper, which will cause a short circuit!
Brass locknuts should of been used, or as you suggested, use plastic Stuffers.
As for isolating the earthing for each building, how will the earth fault protection work for the buildings?
thought they might be cuts and the pattern is right for reducing eddy currents :), I use sharpies so much now it looks identical to a Line drawn by one :). Personally I like double insulated tri rated singles for big stuff, in trunking with as you say large stuffing glands. You can only do what your told, been there too!. Quick pic and email it to yourself for a timeline and a little note with your concerns bit of evidence gathering ;).
ground up lighters on domestic property
Johnboy. I've honestly got no idea mate. I'm just a sparks. I assume that as the individual earthing arrangements for the buildings aren't disturbed / isolated they would work in the same way as if the local supply was being used not the genset. I.e down the CPC, through the main earth and down the DNO earth?
Pennywise ive got some other pics somewhere on my phone of a genset install in london. 1MVA though. All the cables were 300mm tri-rate (TQ I think it was called) in parallel or tri-foil. Much better job. Ally cleats, PVC stuffing glands ect. Same firm but different foreman. Gave me the correct stuff for the job. No arguing, no worries, loads of scrap!
What fittings are these mate? Looks spot on.
customer supplied them £200 each dual housing ,70w halogen pretty expensive but worth it especially when there going to be burried in ground , alot to be said for get what you pay for .
where also pre wired and sealed so water ingress should be less than minimal
Thats beautiful...i want this kitchen
Really?? it may look beautiful, but it wont operate too well as a kitchen with no-where to plug in appliances. Your missus will soon get the Ike with it. It's a designer kitchen that is there purely to look at and not much else!! lol!!
I don't care how functional it is..... your right, thats the missus' problem. Come on man.
As long as that fridge keeps my beer cold and the cooker turns on, i'm a happy man.
best bit about it, is the over head "orders giving" platform. Where i can stand and watch her cook, whilst barking orders and supervising the steak as she cooks it.
Again, ...Your only seeing what the designer wants you to see!! lol!! He ain't gonna tell you about how the upstairs is going to stink to high heaven of kitchen smells that are going to raise up that opening!! Bloody disaster of a layout, when you stop and think about it, and got past how it Looks!! lol!!
Spudnik,
Dan,
