DuaneMHunt1976
With shower say 10mm is dam hard to move, would 2x6mm or 6mm+2x2.5mm as being more manageable
Still the same cross sectional area
Discuss Shower Cable in the UK Electrical Forum area at ElectriciansForums.net
This is the way forward1mm has a ccc around 12/13A depending on conditions, let's say 10A for ease of maths.
So for a 40A supply you would only need 4off 1mm cables.
Use a 2.5mm and limit the running time of the shower to 2 minutes 41 seconds using a timer.
Set the timer to re energise after 10 minutes to allow for thermal effects.
Check the calcs yourself if you dont believe me. :conehead:
I have just read this and my thoughts are, why are people even talking of using more than one cable, just use the "correct" size and do it properly, anything other than that is just stupid IMO.
I don't think anyone is being serious petal. Maybe the OP, but even then I think this thread was possibly a joke that didn't translate to the internet very well.
OK how long you been in that pub Dave, I'm jealous. :wink_smile:
agreed.most showers will run happily on a 2.5mm, strung over the bath and second duty as a knicker dryer.Totally agree with Dave on this one,when you are installing large supplies sometimes you have to install large cables in parallel because the cables can become unmanageable however the same does not apply when installing a shower cable.
All joking aside though, I think anything over 9.5kW on an instantaneous electric shower is getting a bit ridiculous and unnecessary too.
BS7671 specifically permits paralleling cables, with certain provisos on cable route, type, etc. to ensure equal current sharing.I'd be interested to know if there's actually a reg that forbids it in the UK, I know there isn't in our domestic regs. As said already, it's common practice with cables in larger distribution networks but the logistics of ensuring identical lengths, routes and connecting a parallel cabled domestic final circuit would make it a bad idea.
I think id be more concerned about one of them being disconnected then overloading the remain one.
You will not need to worry in another few years because of the EU the power of vacuum cleaners are being restricted next they are going to restrict our power tools so soon your showers will be a maximum of 3KW and you will have a fine mist spray to that you reduce your need for so much water and then to round it off your bath towels will be the size of face cloths ! pmsl
As long as the two pull cords are tied together to ensure isolation of both at the same time.Cant see why the op doesn't go for 2 x 8Kw showers side by side with a 6mm T&E for each, LOL....
Reply to Shower Cable in the UK Electrical Forum area at ElectriciansForums.net
