Shower cable | Page 2 | on ElectriciansForums
Discuss Shower cable in the Australia area at ElectriciansForums.net
W
wingnot71
Hi all, replacing an old shower and I need to extend the cable slightly. The cable(10mm) runs through the loft void and down a stud wall to the isolaing switch. Can I add a junction box in the loft and run the new length down from there or do I have to run it back to the isolating switch as to do this the cost of cable would double. If I can use a junction box would a 30amp box be ok, The new shower is 9.5kw.
Many thanks...
Don't like to brag but ive scotch casted a few 185mm 4 core swa cables if that helps
Reply to Shower cable in the Australia area at ElectriciansForums.net
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
Better off with the click prw213 as it has twin screw termination.
