Shower circuit only RCD | Page 2 | on ElectriciansForums
Discuss Shower circuit only RCD in the Australia area at ElectriciansForums.net
T
TPES
I'd just like some views on my method for installing a shower circuit.
Plumber has asked me to install new shower circuit on a job he's doing, Customer has an old re-wireable CU, and doesnt want to pay for new CU change..
The only work i have been asked to do is install new shower circuit.. NOTHING ELSE.
So i wont be toucing the lights, Downflow heater or any other circuit in bathroom.
So i was going to split the tails at meter and install a dedicated shower unit, Just for shower, giving the shower 30ma protection, All other circuits will be on the old re-wireable board, as i will not have anything to do with these circuits..
I will be upgrading the bonding to incoming services, testing, and notification.
Job done..
Is there anything ive missed...??
And ok to leave other circuits on re-wireable board as wont be touching them..??
Yeah, I think most things boil down to "manufacturers instructions". You could say that the switching device would be protected by overcurrent such in the fact that it is unlikely that a fixed load is going to pull more current than it is designed for.
Just my thoughts...
Yes was thinking that myself but the reg clearly states 'shall be protected with a device' so I guess if no device is present for overcurrent then its not to regs.
I guess this is why a shower supply unit has RCBO.
Reply to Shower circuit only RCD in the Australia area at ElectriciansForums.net
It’s quite common for an electrician to criticise another’s work as you will rarely get everything perfect.
ok cheers for the help lads
