The problem here is the short time the shower operates for,
Years ago our company added lots of heaters to a ring main in a school, despite me protesting as the QS that it was non compliant, and should be on a dedicated ring or radial circuits, every winter the circuit would trip after about 6 hours , I calculated there was a load of 4 x 12 Amps = 48 amps plus other stuff on the ring yet took 6 hours to trip on a 32amp ring !
The 32amp mcb will likely trip on overload as 9.5kw is 39amps at 240v or 41amps at 230v. Advise a down rate size of shower to suit cable or they need to upgrade it to 10mm2 for the 9.5kw
Is there any signs of over heating at all the terminals?
If the shower is rated 9.5KW at 240V then at 230V it's 38A.
if installed ref. method C, 6.0mm is pessimistically rated @ 47A. what's the problem? shower is only 39.5A @ 240V, and that's probably over rated. bet a clamp meter would show no more than 35A. no code.move on.
That only applies if clipped direct , none are always underfloor and through roof!
I still think 32 amp MCB is safe until shower circuit is rewired which was the point I was trying to make ?
Well that's another debate as some people may say cables installed underfloor boards should be reference method B
Others may not agree so the cable could be under the boards and chased and buried in the wall which may make it reference method C.
salisbury
Shower EICR Code- 9.5kW- 40amp mcb!. De rate MCB to 32 or rewire cable to 10mm
CM 1,
Baddegg,
