Shower extractor fan off socket circuit | on ElectriciansForums
Discuss Shower extractor fan off socket circuit in the UK Electrical Forum area at ElectriciansForums.net
impish15
Trainee
Supporter
Bromley
Hi
Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired into the socket circuit not the lighting circuit (I have never seen this set up before) and hasn’t been fused down. So because of the way the extractor fan has been wired spured off the ring socket with no switch/isolation the fan runs 24/7.
The option to resolve the issue with the fan constantly running and the fact it hasn’t been fused I was thinking of identifying the fed (from the living room next door assuming) to the extractor fan installing a new 3amp fused switch (next to the switch in the sitting room) for the fan. I would have attempted to connect the fan to the lighting circuit and add an isolator but the walls are tiled and this would cause a lot of damage.
Please let me know if I have missed something or a better way of doing this.
Thanks in advance
If I've understood right, another option might be a fan with a PIR on it, so it would continue to extract for a duration after a shower.
The Vent-Axia Svara fan might be a good choice. It has Light, Humidity Sensor & Overrun Timer and delayed start and can be App Controlled via smart phone or tablet.
Reply to Shower extractor fan off socket circuit in the UK Electrical Forum area at ElectriciansForums.net
I think you are going to need an electrician because it looks like someone has used the bare earth (has been sleeved black) as a live conductor...
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
