shower fitted by friend | Page 2 | on ElectriciansForums
Discuss shower fitted by friend in the UK Electrical Forum area at ElectriciansForums.net
Baker1988
Kingston Upon Hull
hi all just a quick question my girlfriend dad has just had a shower fitted cos his old one has broke (just a like for like)it was just a friend of his who did it for him dont think he is a spark just had some experiance i have checked it at the request of my girlfriend as she does not trust her dads friend it all seems fine there is not test sheets with it so i did a few tests zs and ir and all seems fine the only problem i have got is that the board has no rcd it is a old board but not really old it has mcbs and even a few rcbos buti told him he should really have a rcd on the shower circuit but i would probily be easier to get a rcbo for the circuit but he does not want to shell out the ÂŁ27 for it so my girlfriend said she will buy it if i think it needs it just so he is safe so what do you all think does it need one i think it does but thought i would ask you lot first
The girlfriend is paying for the bits which will improve the safety of the circuit in question....only expense to you is time to do the job which will likely be a freebie BUT take into account how grateful your girlfriend will be (nudge, nudge, wink, wink, say no more) i'd suggest stop thinking/talking about it and just slip it in (the rcd protection that is.....)
whats the age of the board got to do with the compliance of the circuit?...lol..
jesus wept...lol...
A few things to say about this one.
Was it a requirement for rcd protection at the time of the original install?
RCBO's are single or double pole, depends on which one you buy.
If you did a like for like socket face change on a 1970's install and the Ze, Zs was ok, would you demand that circuit to be on a rcd? Whats the difference for a shower??? (apart from its a shower and is now deemed dangerous and we would all like to see it on a rcd/rcbo)
Manufacturers instructions supersede the 7671 as said before, what do the instructions say?
Taken from the ESC FAQ page.....
"Q2.10If I replace an existing electric shower, do I now have to provide RCD protection for it?
No, unless RCD protection is required by the manufacturer’s installation instructions, or a new circuit is required (to provide for increased load, for example).
Regulation number(s)
  • 134.1.1
  • 510.3"
I'd still fit an RCBO (double pole) or a stand alone rcd, we all would.
My moneys in the instructions for the replacement shower insisting an RCD is fitted.
Therefore.....even though its a replacement, an RCD is now required. Because thats what it says in the book of the one you are fitting!
I'd take swicades tack. Sort it out yourself & reap the (eh hem) reward.
As mentioned will be a pig to get the 10mm in the Rcbo reliably, always is a game.
Took two hours doing an isolator (ceiling) once. Fitted like a glove and was a work of art (was a good paying job!). Better than ramming it up desperately screwing it all together, only to hear the sickening crunch & crack of a shattering patress.....arrrggghh
A couple of points.
When replacing items of equipment, it does not have to be on a like for like basis for it not to be notifiable.
As such you can replace an 8.5kW shower with a 10.5kW shower as long as the wiring is appropriately sized for the load.
You can also replace CPDs higher or lower rated, or even of a differnt type without notification.
It's when the wiring is altered that it becomes notifiable.
Reply to shower fitted by friend in the UK Electrical Forum area at ElectriciansForums.net
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
It’s quite common for an electrician to criticise another’s work as you will rarely get everything perfect.
