Shower Installation 8kw to 8.5kw | Page 2 | on ElectriciansForums
Discuss Shower Installation 8kw to 8.5kw in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It doesn't need to. It only needs to cope with the load. The 40A circuit breaker only needs to provide adequate fault protection.
I know, but you were not supposed to say that, hence my post to the young sparks, now where is the "I'm angry an experienced spark has trashed my post emoji?"
for 8.5kW, Ib= 36A, so unless the cable is covered in insulation, 6.0mm will be fine.
Agreed, no problem at all, the only question now to the OP is "why isn't it already up on the wall?"
Yes it does. Just not sure what the rating of the shower one is. A new board was put in about 5 years ago and I'm assuming all was ok for the 8kw shower we already have.
Assume! Not a good idea.
Did you get certification and building control notification when it was fitted?
If you did then I possibly would lean towards assumption everything is ok, but if it didn't I wouldn't.
Also it's had 5 years of deterioration.
Reply to Shower Installation 8kw to 8.5kw in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, i am wondering if anyone has any experience with a 7.5-8kw shower that has a pump or some sort of boost internally fitted? Working at a hotel...
The whole thing looks a bit of a mess, hanging cables and junction boxes, 15A fuse holder fitted to 30A base etc.
