Shower isolation outside bathroom | on ElectriciansForums
Discuss Shower isolation outside bathroom in the UK Electrical Forum area at ElectriciansForums.net
M
markthespark
Hello just been to look at a shower install the consumer unit backs on to the wall that the shower is going on so the easiest option would be to fit an isolator below the consumer unit and drill straight through the wall.
Would this be ok to do or will i have to put the isolator outside the bathroom door?
For information its a single story flat no access above or below.
cheers.
cheers.
Yeah, definatly. What a nice easy job that one is eh. Has it got a spare RCD protected B40 MCB in DB aswell just to make it the perfect job :). Good point Dave... Electric or power shower?
I would say this is not really acceptable personally, and I certainly wouldn't do it that way.
I was taught that in domestic installations isolators should be installed adjacent to and in the same room as the equipment they isolate. And that a special case is made for bathrooms where the isolator a get installed adjacent to the door into the room.
Sorry its an electric shower, 10.5KW running a 10mm cable in for it, no RCD in the board so going to henley block the tails into an rcd shower unit then out the bottom of that into a 45amp DP isolator just was unsure as its not inside the bathroom or directly outside.
the door for the bathroom is around the corner from the consumer unit about 3 metres away.
thanks
To be honest ive not even seen the shower, its a tenanted flat and the landlord say they have got a 10.5kw shower.
if the isolator cant be fittes below the CU then ill have to run trunking around the top of the wall and drop down outside the bathroom door which id rather not do.
thanks
Yep that's fine as long as the customer knows where is it or it's labeled should be fine, Dave all electrical calculations are worked out on 230v not 240v
No they aren't! Calculations are worked out on the voltage of whatever system you are working with! That's why all of the equations use V not just the number 230!
Most showers still have their power ratings quoted at 240V with their 230V rating appended to it.
Page 294 regs book I'm sure there's others too, they are worked out by nominal voltage not v!
I really do despair for the state of this once noble trade!
Forget the regs book we are dealing with basic physics! V=I.R P=I.V not 230=I.R or P=Ix230
Installation calculations are carried out using nominal voltage in the absence of any more accurate information.
Power ratings are quoted at a specific voltage, to then use a different voltage in calculations involving that power rating is wrong as the power will be different at a different voltage.
Electric showers are almost universally rated at 240V so you need to use 240V in any calculation relating to their power rating.
So for a 10.5KW shower at 240V we get a current flow of 43.75A
If we did as you suggest and used 230 instead then we would wrongly calculate the current as being 45.7A
To establish the actual current flow at 230V we would need to first work out the impedance of the load (R in the above formulas) then we could work out the power and current at 230V
design....
Reply to Shower isolation outside bathroom in the UK Electrical Forum area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
ok cheers for the help lads
