Shower isolator | on ElectriciansForums
Discuss Shower isolator in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Ross1
Hi guysCan I put a shower isolator in zone 2?Also can I put the isolated on the outside wall of shower ( same wall as door )
Does that relate to the first part of question Telectrix?Can I put a wall switch on the out side of bathroom
yes. wall switch on outside of room. inside bathroom, within zone 2 it's got to be a pull cord.
if its more than 600mm from the edge of the bath and outside the zones then it can go in the bathroom but as tel has said as its in zone 2
The switch body of a pull-cord isolator must be mounted outside the zones, but the cord may hang within Zone 2. Therefore a switch body fixed on the ceiling above Zone 2 must be mounted such that all of it is >=2.25m above the fixed floor level.
Reply to Shower isolator in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
