shower location | on ElectriciansForums
Discuss shower location in the UK Electrical Forum area at ElectriciansForums.net
P
Pockets
Does a new circuit feeding heaters in a changing room of a sports pavillion require rcd protection? as the shower room for it has no door and the fixed water outlet is 1.4M away from the nearest heater. so is the changing room part of the location containing a shower? Thanks for any thoughts on the subject.
Reply to shower location in the UK Electrical Forum area at ElectriciansForums.net
You need a CT clamp at main tails, it depends on the rules where you are - you used to be allowed wireliss ones (such as MyEnergi Harvi), these...
Stick the socket in a large plastic wall box with hinge and padlock. Give customer letter with key...
4K
