shower old for new | on ElectriciansForums
Discuss shower old for new in the Australia area at ElectriciansForums.net
sunny essex
Hi allA customers shower needs replacing ( old for new ) apart from me doing electricial tests zs,rcd ect for the circuit can the shower be replaced if bonding is not 10mm and also is this classed as minor works even though its in the bathroomThanksRich
Minor works as there is no new circuit being installed. Or circuit protection?
And a note about undersized bonding on the cert.
You could also argue that it would not need notifying as its a like for like replacement.
Or is it?
Then again, it is in a special location.
Reply to shower old for new in the Australia area at ElectriciansForums.net
Given the apparent lack of earth, combined with no short circuit or over current protection, I'd contend that luck has been the sole factor...
nicebutdim
N
It’s quite common for an electrician to criticise another’s work as you will rarely get everything perfect.
