shower rcd | on ElectriciansForums
Discuss shower rcd in the Australia area at ElectriciansForums.net
sunny essex
Hi all
Have been to see shower replace (old for new) consumer unit has dedicated 32a mcb for shower circuit using 6mm cable but no rcd. question is can i cut into the 6mm cable from consumer unit install a rcd and then carry on to shower still on 6mm also can only find shower rcds with 40a breakers do i need to change breaker to 32a
thanks
Rich
Hi lenny
yes checked the regs and cable can carry 34amps so no greater than 32a breaker in the cu ,also its a cu with 3036,s and they have plug in mcb,s so i understand no rcds can be pluged into board,i will go with mark the spark,
Reply to shower rcd in the Australia area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
