Shower sets off Smoke alarm | on ElectriciansForums
Discuss Shower sets off Smoke alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
N
ngoodson1969
Hi all,
I have a strange problem. have just installed 2 smokes and a heat alarm in a property. When the shower is turned on it IMMEDIATELY sets off the alarms. The alarms are all RF and talk to one another. The shower is on it's own circuit. Any ideas?
Regards
Nick
Both ionization and photoelectric detectors are effective smoke sensors. Both types of smoke detectors must pass the same test to be certified as UL smoke detectors. Ionization detectors respond more quickly to flaming fires with smaller combustion particles; photoelectric detectors respond more quickly to smoldering fires. In either type of detector, steam or high humidity can lead to condensation on the circuit board and sensor, causing the alarm to sound.
;How Do Smoke Detectors Work?
its almost certainly steam from the shower ( very similar to smoke as far as a basic ionisation smoke detector is concerned ) and is a very common problem.
solution? the quickest and most effective way is to simply swap the unit for a heat detector. :cool:
That is strange... I'm thinking interference.... unless a serge in the shower? Maybe a type c breaker? Not sure...
Reply to Shower sets off Smoke alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
This is it though…. To put one following the letter of the law, so to speak… would be a smoke in the hallway outside the bedroom door… then a heat...
hi yes i agree its a final pir circuit with 30 seconds entry and exit programmed in no other detectors on route to rkp tried a different...
