Shower shocker
J
James Sutton
Hello All
Was asked by a mate to take a look at his shower in a flat that he rents.
He is in the shower for around 10 mins the the 4OA mcb trips and gets a strong smell of burning.
I opened up the 45A DP pullcord everything was ok there all connections tight. It had what appeared to be a 10mm flat twin and earth(grey). Went down to the CU and there was a white cable. Further investigation found that in the loft space they had joined both cable using 32A connector block which was completed melted. I LOTO the shower circuit and said for him to contact his landlords.
Who does work like this its a shocker
JS
