Shower Swap require RCD install? | Page 2 | on ElectriciansForums
Discuss Shower Swap require RCD install? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Just saying e.g. scenario, if supply is PME (can't be arsed with modern descriptive) 16mm tails and 6mm bonding, no sign of thermal damage etc, nice shiny RCD in CU, 'customer you need to upgrade your bonding'; 'how much, your having a laugh, I just want my shower replaced, cos the smell's putting the dog off'.
What do you do?
What do you do?
That would only be considered a C3, so would be complient.
Apart from the fact that this thread is not discussing EICRs, if an observation warrants a C3 code then it is not compliant.
C3 is the code given when an observation is not immediately nor potentially dangerous, but does not comply with the regulations and if it was changed to meet the regulations it would improve the safety of the installation.
Yes thats right, i didnt quite word that right. However work could still proceed.
Reply to Shower Swap require RCD install? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
I am with you. Their RCD did not comply with the standard. The only one I know that does comply, though I am sure it isn't alone, is the Garo...
