Shower upgrade and mcb size | on ElectriciansForums
Discuss Shower upgrade and mcb size in the UK Electrical Forum area at ElectriciansForums.net
Norton
Hi there.I am looking to upgrade my daughters shower in her flat.The shower is a 7.5kw at the moment,but is struggling with producing a decent temperature with the weather as it is.I was aanting to put in a 9.5kw instead.I have checked the cable from the mcb to the pull switch,and by posts i have read,seems to be 6mm.This runs about 6 feet to the switch,and another 6 feet from the switch to the shower.I have added photos of the fuse which is on its own board,which reads 63A.Am i missing something,as I was prepared to upgrade 6mm to 10mm,but unsure why such a large fuse.Any help would be greatfully received.cheers
[ElectriciansForums.net] Shower upgrade and mcb size
Also the 63amp you refer to is the main rcd, I'm guessing the 50amp next to it is for the shower
Paul, the 63a you refer to is the current capacity of the RCD ,in other words it's designed to handle that amount of current. The overcurrent protection is currently a 50 amp MCB rather than a fuse, this unit would have been bought as a 'Shower unit'. For the length of cable run you describe and assuming it's not covered by any insulation I'd say you could go up to 9kW safely with the new shower unit. But remember this is a notifiable job under Part P.
Is the flat her own or rented? Working 10mm and effectively terminating it properly and testing afterwards is a skilled job. If rented make sure the Landlord has agreed. I have never like the idea of standing under an electric shower so counter-intuitive.
Hi - if I could advise you - this is not something you can take on as a DIY project. I've fixed a few that have had potential to be deadly without the upgrade you're contemplating. There's just no way I know for you to learn enough from the internet to safely undertake this job.
I wouldn't say that, all the information needed is online to do this job.
However, the time taken to do this and the cost of test equipment, notification etc... It's just far easier and a lot cheaper to bring a qualified electrician in.
hmmmmm. a 50A MCB is a bit of a low rating to provide over current protection for 6.0mm cable, but..... a sthe shower is a fixed load then it only needs short circuit protection. a 9kW shower is within the capability of 6.0mmcable, assuming not in insulation, so a shower replacement on the existing circuit should be straight forward. if in doubt though, consult a competent spark.
Yep and that run in the photo looks pretty itchy poo free and full of free air making a good ccc for a ‘slight’ upgrade (by a competent qualified electrician!)
Reply to Shower upgrade and mcb size in the UK Electrical Forum area at ElectriciansForums.net
